.2 quart over on oil fill a problem?
OS
15,581
I just changed my oil, I was a little sloppy and added a bit too much oil, about .2 quarts too much. My car takes 4.4 quarts and I used 5 1 quart bottles and have 4/10s a quart left. :\
What is the easiest way to remove the extra?
Kilgor
3,292
If it really bothers you just take the oil filter off and drain it should be about equal to what you over filled.
Sid59
11,879
your car is gonna explode. take it to the dealership so they can steal more of your money.
Eli
Super Moderator | Elite Member
8
LOL.. No.
But uh, whoever says they overfill their car by a quart.. that is too much. There is a reason theres a limit.
TechnoKid
5,575
Originally posted by: MadCowDisease
Originally posted by: Pepsi90919
lmao
no.
i overfill mine by like 1L all the time
Enjoy replacing your engine seals.
how would additional oil mean new seals? The only thing i could think of the more oil would do is create more oil on the crank; the windage tray will not be able to keep the extra oil off the crank. Alot of oil pans can hold about 1 quart more than what the dipstick indicates, however, for all practical purposes, I wouldn't want to run with 1 quart over, unless i had a properly baffled oil pan, and was say racing the car on a oval track or autox.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: Wingznut
Running an engine with an extra quart of oil is not even a big deal.
Depends on the engine. If it's a big-block that takes 6-7 quarts as a baseline then it's probably at the upper limit of OK. If it's less than 3.0 litres, that extra quart will get whipped into a nice froth by the crank, increase crankcase pressure, and blow out at least one of the following: Front main seal, rear main seal, or the PCV valve.
The general advice is that an engine can tolerate up to 0.5 quart of extra oil without it becoming a problem.
ZV
