UncleBastard
I got a P4 1.8a and an abit BG7 motherboard yesterday and so far I *think* I have it stable at 2.4ghz. Using the winbond hardware doctor thing that came on the driver CD and from reading old posts my temps seem a little high. I'm using the Heatsink and fan that came with the CPU. Idle temps seem to be around 46-48 and under load it goes between 55-57. Even when the CPU is at the default speed of 1.8ghz the idle temps mostly stay around 45-46. My case has a fan mounted on the side pannel that blows cool air in right over the CPU and it also has a fan on the back of the case that blows air out. Case temps idle are around 36. Under load case temps go up to 40 or 41.
So if you think these temps seem a little high the only thing I can think of doing is re-doing the arctic silver. I'm not sure if I did it right the first time. What I did was put a dab about the size of a pea in the middle of the CPU and then installed the heatsink. From reading old posts it sounds like what I should have done was spread the AS over the whole heat spreader area and then install the heatsink. It this correct?
So if I redo the AS is it ok to clean both CPU die and heatsink with isopropyl alcohol?
