I just moved into an apartment and I have high end TV & electronics and a computer all of which I had used quality surge suppressors. This new apartment only has 2 prong outlets no ground. 1st) Will a typical 3 prong to 2 prong adapter (cost under $1) actually serve as the needed ground for protection as the Landlord suggests ? 2nd) Will the surge suppressors work using these 3 to 2 prong adapter or lose effectiveness?. 3rd) One Tv I have is 46" Sony HD LCD, purchased a year ago and the TV only has a 2 prong plug, can I assume that the TV has ground wire built in? Lastly, For the moment I am just unplugging items when not in use to avoid the increased potential of a surge occurring when I am not even using the equip, but I am also concerned that unplugging a unit like my LCD TV a few times a day can in and of itself be harmful to the TV is?
Thanks for any help you can give to any of these questions.
It's late and I'm tired, but briefly:
Get a 3-prong-to-2-prong adapter like you said, then get one of these
http://www.amazon.com/Gardner-GFI-50...ef=pd_sim_hi_3
and plug it into your outlet and see what you get. It will tell you if the outlet/circuit is grounded or not and if there's a floating ground. Cheap, quick & easy. I have one and it works perfectly.
Note that you can't assume a 2-prong outlet is
not grounded. IIRC, an electrician once told me that even 2-prong outlets have to be grounded to the fuse panel outside the building. (For a house, that's usually on the home's outside wall in the backyard. I dunno about an apartment.)
But again, that device I linked to earlier should tell you the answer instantly.
NOTE: You can also find those devices at places like Lowe's and OSH.
You asked: "Lastly, For the moment I am just unplugging items when not in use to avoid the increased potential of a surge occurring when I am not even using the equip, but I am also concerned that unplugging a unit like my LCD TV a few times a day can in and of itself be harmful to the TV is?"
Unless you live in an area with a lot of electrical storms, unplugging devices all the time shouldn't be necessary. And unless your building has horrendous electrical wiring, or the power grid is messed up, you shouldn't get a lot of surges/spikes either. AFAIK, the really serious ones are caused by lightning strikes on or near a power pole/line in the area. At least that's how it is where I live. I've never had a power surge/spike damage any plugged-in devices (most of which aren't plugged into surge protectors).
I doubt if unplugging the TV several times a day will hurt it. What
might happen over time, however, is that repeated plugging in and unplugging could cause the contacts in the outlet to get loose, and the TV's plug won't fit snugly anymore. At that point, the outlet would need to be replaced.
Note that I was also told by the same electrician that running a GND wire to a water pipe
can cause an electrolytic reaction and cause the pipes to corrode on the inside (and then develop leaks). And once the reaction starts, it's hard to stop it from progressing. No joke. I'm guessing you don't want your landlord to sue you, so you might try n' get the OK from him/her before you do that. I'm not an electrician though -- I'm just tellin' you what I've been told.
