Overkiller
Hello,
recently i did a reformat on my 36GB Raptor HD. I left the brand-new 80 GB WD (previously drive letter F) alone as i JUST got it and was using it for storage. After a reformat/reinstall of WinXP the 80GB WD is c:/ and the 36 GB Raptor is D:/
Not that big of a deal...i can live with that (although i would like to see them switched..but i can't in Drive Manager)
I however cannot boot-up w/out having the WInXp cd in the dvd-drive. EVen when i set it to boot off Hard-Disk first it doesn't, says "error boot disk, insert boot disk and retry." When i leave the WinXP cd in there it says "boot from cd......" and then XP just boots up normally if i dont press anything..
how can i fix this?
Secondly,
WHen i install the dirvers (Catalyst 4.2) for my 9700 PRO under "smartgart" it sets Fast Writes to : OFF and AGP SPEED: OFF,
when i set it to 8X/4x and fast-writes on it says "must restart to see if settings are ok". It restarts and it reverts both settings to OFF.
how can i fix this as well? Thanks!
how can i fix this?
Secondly,
