- May 2, 2001
- 7,682
- 0
- 0
First problem: I have a couple of computers i am trying to get connected, first is my computer that is obviously connected. Second is a computer in the living room which absolutely will not work with this 35 foot cable I have. No problem i thought it must be the cable, so i moved the computer into my room and plugged it in with a 6 foot cable i have laying around, poof it works. I get a new 35 foot cable for the computer move it back and plug it in, nothing. I then plug in that cable thinking no way 2 cables wont work into my computer and it works. I don't know what to do about this, i have tried multiple ports on the router all with the same results. Cable works just not for that computer, other shorter cables work but they won't reach into the living room.
Second problem: When i connect cross-over cables from comp to comp i was getting a transfer rate of a whoppin 7k! I don't know what the problem is here either, i tried multiple cables to no avail.
Any help is appreciated, TIA.
