2 Problems (Permissions and Shares)
BuudWeizErr
In my attempt to get MCSE Certs, I decided to set up a Win2k Server box in my house and serve a few computers for some hands-on experience. For the most part, things are going good, but some annoying problems have popped up, and I haven't been able to remedy them.
1) 2 computers and the server-My main box is XP Pro. The second box is a Win95B. And the third is my Win2k Server. I have some shares on my XP computer that I tried to access from the server and from the Win95 computer. No go. I get the "Enter Network Password" Prompt. I can't get in to see the share names, when I doubleclick the computer, that prompt comes up. However, I can access shares on the server from my XP and 95 computer. I can access shares on the 95 computer from the server and the XP computer. The server and my XP box both have the same admin name/password. Also, ICF IS disabled on the XP box.
2) If I go and try to set the permissions on one of the shares on my server, I go to add an account, and if I add Administrator or the username I use for my server/xp computer, I can't access the share. So then, I try to add an account from my XPbox, but the Look in: drop down box is greyed out. Do I have to be in a domain environment to set permissions that way? I need to share files off the server for my XPbox, but there are folders I don't want accessible from the Win95 box.
Any thoughts? Confused? 🙂
OK, well I figured out the problem in case anyone else runs into this and searches. It is an XP problem.
To fix it, go start, run, "secpol.msc" local policies, security options, then find "Network Access: Sharing and security model for local accounts" Double click that and change it to "Classic - local users authenticate as themselves."
Problem solved.
