vailr
Hello,
Trying to set up a simple 2 desktop machine home network using a CAT5 crossover cable:
A cable modem is attached (via normal CAT5) to a PCI NIC in the base machine. The 2nd machine is connected via PCI NIC, and CAT5 crossover cable, going to a Belkin USB-Ethernet adapter (in the base machine). WinXP Pro on both machines. Have used the "Network Setup Wizard", but cannot get the setup working. Is the crossover cable bad? Or is the Belkin USB-Ethernet adapter causing the problem?
Note: The Belkin USB-Ethernet adapter works fine, when used with a 3rd machine (laptop) connected directly to the cable modem.
TIA, for your help.
TIA, for your help.
