2 logitech wireless stations with 1 k&m combo???
94
I am running 2 boxes and i would really like to be able to switch between them. I think a great way to do this is to just use a wireless keyboard and mouse solution.
Therefore my question is if i get the Logitech itouch cordless Keyboard and mouse combo, cand i just get another wireless base and use the K&m??? I.e. is there any way i can turn off a base station without unpluging it? and are different stations compatible with differnt wireless products?? (i.e if i decide to get a cordless optical mouse.. could i just use that with the current k&m combo?).
Lucky
13,126
i cant get my combo to work properly with a KVM. I've tried both a $300 belkin and a $100 cybex and neither of them work reliably. The keyboard works fine, but the mouse will only work erratically. Sometimes it works, other times, when i move the mouse it just jumps all over the place on-screen. Havent figured out why. When I run it straight thru to the comp, it works.
Shalmanese
2,157
Radio interference from the KVM?
Try plugging only the mouse via KVM and other 2 straight through.
Lucky
13,126
this KVM isnt powered. I currently just share the monitor + KB and physically switch the mouse from computer to computer as a temp. woraround.
94
KVM? Sorry not sure what that mean. So from the posts it seems that if i get another rf receiver from logitech, I will be able to use my keyboard with the 2nd computer???
Does that mean there is some type of "on/off" switch for the rf receiver? Also does anyone know where to get a second rf receiver from logitech? Thanks.
