boxleitnerb
- Nov 1, 2011
- 2,601
- 2
- 81
Not completely but they improved alot. I have seen MS with 4870X2 but not with any of the newer gpus unless the framerate is below 60fps. Any remaining MS can be eliminated with a frame rate limiter with only drawback being slightly lower average fps. CF issues are usually fixed a few days after game release.
MS remains an issue if you use SLI/CF for settings where it is actually needed: 3D, very high resolution (Eyefinity), SSAA etc. Then you barely get above 60.
If the last third of 2011 has shown anything, it is that CF is still quite immature. So many slip ups, I would have been pissed as a customer. There are still many many games where CF doesn't scale beyond 2 GPUs and I have friends that have microstutter or less "smoothness" even well above 60fps.
Although I use the framerate limiter myself (I would have never bought SLI without that in the first place), I'm not completely happy with it. For instance in Skyrim the fps can range from 30 to 150. So if I limit to 30 not to get MS in very demanding scenes, I waste full 120fps in other scenes.
