2 Hard Drive failure questions
BuckleDownBen
Banned
Jun 11, 2001
519
Hi-
On IDE drives-
1) If I am looking at the drive with the pins on the left and the power connector on the right, and I break off the top, rightmost pin (I think this is the ground pin), and the drive still works, what could happen to the drive down the road.
2) If I unplug the power to a drive while the drive is on, and then the computer can't recognize the drive, what exactly has happened, and is there any way to fix it?
Adul
44
danny.tangtam.com
1) You can risk stability and possibly shorten the life of the drive. You may also induce unexplained errors.
2) You can kill the drive, replace it with a new one. (I did it before myself :()
Demon-Xanth
20,551
Unplugging power while the drive is on WILL cause a head crash. Every other pin (the bottom row) on a floppy drive, IDE drive, and SCSI drive, is ground. That is how they got away with DB25 SCSI, they used the shroud as ground instead of 25 more pins.
