2 general MONITOR Questions
Jza
1. Dot Pitch- The lower the dp # the better? or reverse...
2. Refresh Rate- Whats a good Hz # for a 19" monitor, or whats the lowest Hz it can be w/o being bad
The lower the dot pitch the better, you have horiznal dot pitch and diagonal dot pitch most good monitors are in the 0.24 diagonal range.
lowest 65hz I keep mine 85hz
'They' recommend that you have a refresh rate of at least 75 Hz to reduce eye strain, but I also like to use @ at least 85 Hz.
The refresh rate is usually determined by the resolution you will be running the monitor at. Personally, for a 19" monitor, I feel that it should at least support 85Hz @ 1280 X 960 (or 1024). The monitors listed in your other post all meet this except for the Samsing 955df which officially supports only up to 75 Hz.
