2 DVI + 1 VGA ... possible ?
RikyRoby
4
Hello !
Just an information, if in a motherboard like the MSI K8NGM2-FID, wich has
the DVI and the VGA output, i'll put another vga card with a DVI output, in result i have 2 dvi output + 1 vga or the onboard outputs are stopped ?
Thank you !!!!!
renethx
1,161
No problem. I tested various configurations using 4 LCDs. Any combinations worked.
RikyRoby
4
You mean that i can connect
1)TV LCD (dvi 1920x1080)
2)Monitor Lcd (DVI 1280x1024)
3)VPR (VGA 848x480)
With no problem at all ?
That's fantastic !
renethx
1,161
Well, I tested only with 4 LCD monitors connected to onboard DVI/VGA and a dual-head PCI-e video card. I cannot speak of other configurations (in paritcular TV LCD).
RikyRoby
4
Ok, but all the 4 video outputs (3 DVI and 1 VGA) wokrs
at the same time right ?
(usually if you put a video card on a mobo with onboard vga, this one is cut off)
renethx
1,161
Yes, all 4 video outs (either 3 DVI+ 1 VGA or 2 DVI + 2 VGA or 1 DVI + 3 VGA) connected to 4 LCD monitors work simultaneously.
