2 Broadband Conneciton Join with NIC cards Possible??
TatSteeL
247
Ok I have Sprints Broadband and Adelphia Power Link. Is there a way I can join them together to make a faster connection or is there a way I can use both connection on the same PC doesn't matter if its join or not. Like going into mIRC with two connection on the same channel that way its not clone or d/l from internet using Power Link and the other d/l using Sprints Broadband.
sohcrates
7,949
well, win2k server and linux both support forms of "load balancing"
i have NO idea how to configure it, but in theory it would let you utilize double the bandwidth with 2 broadband connections
if nothing else, search for "load balancing" here and there and you'll probably come across some good stuff
TatSteeL
247
Thanks all, didn't know that there's a way u can join 2 broadband connection with win2k server or using the router.
