2.8 MO SL6Z5 @ 3.3gig => *stuck* at 236fsb => any advice ?
BEIF
Hello
Can people please help me figure out if I have *missed" something *OR* am I just one of the [relativley] "unlucky" ones whose 2.8MO wont go too high.
Setup is:-
- P4P800
- Latest 1016 BIOS
- 2.8 MO SL6Z5 @ 236mhz fsb @ 1:1 memory @ 3/4/4/8 = 3.3gig
- Costa Rica / Pack Date Feb 9 2004 / FPO Batch 3351A279
- 2 x 512 Hynix D43 DDR @ 2.75v @ 1:1
- Memory ratio set to 1:1 / 400
- BIOS CPU Voltage set to 1.6000v
- DDR voltage is 2.75v
- AGP voltage is 1.60v
- P4P800 "idle" CPU voltage [ via AsusProbe ] = 1.648 <-> 1.664
- P4P800 "load" CPU voltage [ via AsusProbe ] = 1.584 <-> 1.616
- using the Stock cooler with the thermal pad removed and AS3 applied
- Temps are *not* an issue - 30'C idle / 46'C artificial max load
- H/T is OFF in BIOS
- AGP Locked at 66.66 / 33.33
- MAM is on
- Perf Mode is STANDARD [ givee me Partial PAT as per CTIAW ]
- DRAM by SPD is selected - CPUz confirms DDR is at 3/4/4/8 @ 1:1
- Spread Spectrum - DISABLED
- ICH Delay - DISABLED
- PnP O/S - YES
- Pwr Mangt = ENABLED
At these voltages and settings 236fsb is fully P95 stable and system is fully stable.
Please dont get me wrong - 500mhz for free is FANTASTIC as far as I'm concerned, its just that everyone else seems to be hitting ~250mhz at close to stock voltage which is making me suspicious that I have done something wrong.
I *do* know for a fact that this motherboard and these 2 Hynix 512 D43 sticks work perfectly up to 259mhz @ 2.75v @ 1:1 because that is what they were running at in the exact same system with my "old" 2.4C - the *only* thing I have done is upgrade my CPU to a 2.8C MO, so I know it is not the motherboard or ram holding me back - my "old" 2.4C ran at 12 x 259 @ 1:1 @ the above voltage settings fully P95 stable and fully "real world" stable.
So far have tried 2.85v for memory and/or 1.70-1.80 for AGP voltage / and/or MAM off / and or Perf Mode to AUTO all to no avail => anything above 236 either reboots during boot up or during intial Windows XP use or gives me a BSOD during bootup [ before windows has finished loading ]
So .... I *seem* to be left with considering upping the voltage for the CPU higher.
Q => do people have any other thoughts / options I could try ?
Given my voltage is 1.6000v in BIOS which equals 1.648 <-> 1.664 at idle and 1.584 <-> 1.616 under load
Q => do I have any more voltage headroom to play with ?
Any comments / thoughts / suggestiosn would be grealty appreciated.
Ben [ BEIF ] Ifin
Forgot to add:-
- I tried the 3:2 and 5:4 memory ratio's but my P4P800 wont boot at all with either a 5:4 or 3:2 memory ratio when the FSB is 230mhz or higher *YET* it happily works at 1:1 at up to 259mhz fsb - go figure !!
Ben [BEIF] Ifin
IIRC, the 2.8C comes with an all-aluminum cooler not, the copper-cored heatsink used for 3+GHz Northwoods and Prescotts. Your temps seem to be a little on the low side for 3.3 GHz, are you sure you're reading the right temperatue? I do know that Abit reads higher temps but my IS7 with a 2.4C@ default vcore @ 3.1 GHz runs hotter than that with a Zalman 7000-AlCu heatsink.
Apart from that, it may just be that this particular CPU just isn't a great overclocker. I'm sure others will have more thoughts, since I am only a mild OC'er 🙂.
Hmmm ....
I thought / assumed that as my cpu-under-load-voltage-range was 1.584v <-> 1.616v , I could still bump it up a little as long as the my cpu-load-voltage-range remainded *below* 1.6500v - the generally accepted *maximum [safe]* voltage for N/W P4's ?
Ben [BEIF] Ifin
Originally posted by: BEIF
Hmmm ....
Ben [BEIF] Ifin
That's true, from what I know, but you're still "stuck" there until you get some good cooling-- a minimum of one intake fan, one exhaust fan and a good aftermarket heatsink/fan, which is known around here as an hsf.
BTW, what are you using to get, as you called it, an "artificial max" temps?
don't worry about what you set it in frequency control, worry about the BIOS Vcore readout.
i set mine to 1.6 in the bios, actual voltage is just hovering around 1.54 ~ 1.55. i wouldn't be exceeding 1.55V readout for an OC IMO.
