2.5" HDD case power requirement
Mayfriday0529
7,187
I just bought this MSI Startray 2.5" HDD enclosure and it came with a funky USB cable.
on one end is the mini usb 2 port and on the other it has two regular USB connectors. I think they call it a USB Y cable.
Anyone ever use one of these? do you have to connect both ports to give the drive power?
If I use a regular single USB port cable the HDD is detected but when you write or access it it keeps disconnecting from the computer. I use the same type of cable on my Western Digital 120 gig Passport drive and works fine.
corkyg
Elite Member | Peripherals
27,370
240
Exactly. Most laptops will not power any external drive reliably with a single USB source. Most good external cases also can accept a small power module - that is better because you don't waste a USB port. Alternatively, use a powered hub.
Old Hippie
6,361
It can also make for an interesting afternoon puzzle. 20 wallwarts with 20 different pieces of equipment......Let's see....which one went to the laptop cooling pad? :confused:
corkyg
27,370
240
Ha, ha! Yeah - that can be an extreme situation - but really, nothing a labler can't resolve. And if you don't like to look at 'em - put 'em under the desk. :)
Mayfriday0529
7,187
thats weird because my western digital works great with one usb port connection.
the only difference is the WD drive is probably a 2.5" SATA drive, the new one is PATA.
corkyg
27,370
240
Originally posted by: Jnetty99
thats weird because my western digital works great with one usb port connection. the only difference is the WD drive is probably a 2.5" SATA drive, the new one is PATA.
SATA power draw is slightly different - maybe more efficient. The majority of external drives I have tried are all 2.5" - Toshiba, Hitachi, Seagate and Fujitsu, and none will work with just a USB connection. A lot depends also on what other USB devices you are running, especially on a laptop. Example, I use a USB wireless mouse, and a USB flash memory device and a USB fingerprint reader. Even with a hub, there's only so much power available in a laptop.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Western Digital Passport drives are optimized for use on a USB 2.0 connection without the requirement of auxiliary power. They have a soft start circuit which minimizes inrush current when plugged in. This eliminates those overloaded USB port messages in Windows or a malfunctioning drive. Seems to work well as I've never plugged one into a system and had it complain.
Those $19 cases OTOH, your mileage may REALLY vary with those. :Q
Old Hippie
6,361
Coupla' things to be learned here;
1.) You get what ya' pay for
2.) This lady has soo much knowledge, it's just plain scary
mercanucaribe
Banned
Oct 20, 2004
9,763
Yeah, what use is all that knowledge in the kitchen?
Mayfriday0529
7,187
umm $9 bucks actually... i'll try it with the double USB and see how that works.
