2.5 -> 3.5 mounting bracket with same connection position?
kankurou
I have an Alienware X51. I'm installing a 2.5" SSD to replace the 3.5" HDD. Problem is that it's a "slide in" connector. A typical 2.5" to 3.5" bracket changes the position of the SATA connector because it centers the 2.5" ssd in the middle of the bracket, therefore I can't "slide in" the 2.5" SSD because the SATA port isn't matching the 3.5". I'm wondering if there are any brackets that position the SSD to the corner of the bracket so that the SATA position matches the same position as on the 3.5" HDD.
