2.4B
MSI 6580 (845G Max)
1 GB PC2700 (Patriot or Viking, definitely generic, but spd settings are 2.5-3-3-6).
128MB 9800 Pro
80GB 8MB WD HD
My quesiton is: Does a higher clock speed w/ lower mem speed settings win over a lower clock speed w/ higher mem speed settings?
My memory options in BIOS are Auto, 200, 266 and 333. I've left it at auto, and when I OC to 2.7, PC Wizard 2004 says the ram is running at PC2400 speeds. OC'd to 2.7 I can't run the 333 setting, even at very loose timings, it won't boot (have to clear CMOS).
I almost bit on a new A64 rig, but wanted to wait until the 939 platform came out OR should I just build a new rig right now with a OC'd 2500+, new mobo and RAM?
Btw, my system is mainly used for gaming (BF1942 & Vietnam). Temps are iffy, PC is in a not very well ventilated room, so at idle case/mobo are at 32, CPU varies from 36-42, under load I've passed 60C (according to MBM 5). I bought a new HSF, using AC thermal paste, lapped both the cpu and HSF... still not cool enough. Case hase 2 intake 2 outtake fans, so I know the airflow is good.
I digress, and thanks in advance for any insight/help.
