Hmmm..I am getting data corruption at only 2380MHz 140 FSB...!!!!...seems abit low
P4 2.26A @ default VCORE (actual 1.43 Volts being Drawn) (Temp at 50C)
Motherboard = Shuttle FS51 MB. (SIS 651)
Kingston 256Mb DDR 2100 Ram , (4:3) divider ...
IBM Deathstar GXP 75 DLTA 703050
Asustek V8200 GF3...
What could the suspect be...?
-----CPU voltage? its reading 1.43 volts...isn't it supposed to run at 1.50?.....If I have to change it ...would 1.7 Volts be safe...(1.7 volts is the next ---possible voltage setting....to be obtained by VID pin wrapping.....whats the recommended Max voltage on a Pentium 4 Northwood.).. ?
------RAM using 5:4 Divider so its only at at 105 MHz (210MHz) ?
------HDD possible.........I could change it with a Death Star 61.5 Gig HDD ?
-----I managed to get the worst CPU on the block..?
