(2) 120mm fan rad vs (1) 120mm fan rad
Yea, it is quite better.
With a single fan rad, you have to be very careful with the deadzone (where the motor is) - meaning that you should definately use a shroud to get maximum used surface area. Shrouds take up alot of extra room.
With a double 120mm rad, you don't need to worry as much about the dead spot, and you can easily cool CPU, GPU. I'm using a triple 120mm so I can run fans slower, and therefore, quieter.
thanks safeway. but can i still cool the cpu and gpu effectively with just a single 120mm rad w/ shroud?
thanks kensai 🙂
tough decision... dont want to cut the case and dont want to have the rad outside :roll:
Yea. Since you are WC, I'd say that you are adventurous enough to cut your case. Believe me, it's easier than it seems.
If you want performance, but also low noise, a double is the only way to go.
Hell no, unless it's a motorcore. Get a triple. 🙂
Kensai, I am getting a triple. I was being reasonable. If he is iffy about a double, then trip is a 'hell no'.
Hah.
i just got an antec p180... how about 2 single 120mm rads in the loop.... one front and one on the top 😛
Originally posted by: Kensai
That probably wouldn't work too well.
🙁 but thanks for the replies, safeway and kensai!
