2 1/2" to 3 1/2" HDD Adapter HELP!
FXGuy3369
381
Ok so maybe I am an idiot but I bought a 2 1/2" to 3 1/2" hard drive adapter and can not get the drive to recognize, can anyone think of something off the top of their heads that I should need to know?
On one side it has a block for the pins of the laptop hdd ide part, and on the other side it has the block of pins to plug into an IDE cord, and a molex connector. So I plug the laptop hdd into its side, plug the other into and IDE cable, and the molex into a molex from the PSU, but this leaves the 4 pins for power on the laptop HDD untouched, and doesnt show up on my PC.
Zepper
18,998
Is it an ATA66 or higher drive? If so, did you use an 80-wire cable? You will need to unkey the 80-wire cable or cut off the proper pin from the adapter (be careful, once cut those pins are hard to put back) as most of the 80-wire cables come keyed (one hole plugged) from the factory. You can "unkey" a cable with a HOT paper clip - catch my drift. ;) All the pins of the drive should be in the drive side connector (44-pins) - it is NOT keyed so make sure you have pin 1 to pin 1. If not, something's hinky! And pin 1 of the IDE cable has to be on the same end as pin one of the drive.
.bh.
