- Jan 11, 2001
- 28,830
- 17
- 81
I built an HTPC recently and grabbed a low profile cooler from ebay which looks like the typical retail intel cooler.
Upon arrival, there is no copper core, appears to be solid aluminum and the temps are just horrible. Fan runs full speed all the time and is annoyingly loud, system idles in the 40's C and can hit 70+C just running through windows updates and such. I'm looking for something that can perform MUCH better without the excessive noise.
Researching 1U, there doesn't seem to be many options out there for a reasonable price in an active cooler. (I'm horribly cheap, prefer under $20 total if possible.)
I'm guessing 1.5U would yield better options and price, but i'm limited to ~45MM on TOTAL height. Realistically it should probably a bit less so the PSU and HSF don't starve each other for air since they would basically be sitting against each other. I guess I could get a HSF and invert the fan to blow UP into the PSU but i'm not sure how that would affect the cooling capabilities.
