1st video card upgrade, need help
brallen1
Intel extreme quad core 3.0 ghz overclocked to 3.33ghz
(2) nvidia 8800 ultra in SLI
Hp Lp3065 2560-1600 native res
1.1 kw power
4 gig mem
asus striker extreme 680i motherboard
This is a Hp blackbird. One of the video cards died, and i want to replace both cards with the best that this OLD rig can handle! I run charts all day for trading ( other monitor is Hp zr30w ). Love to game at highest res possible per game. If there is any other info you need, i will get it to you.Thank you for you suggestions
What's you budget?
The card in my rig would be quite an improvement in SLI, and run a good bit cooler to boot. They're running about $230 a piece right now.
I didn't want to buy more card than the rest of the rig could use, and I don't know where that threshold is.....
Well, you said you have a 1000 watt PSU, and it ran two 8800s. That is pretty stout, power wise. A better way to ask you question is to tell us what you are thinking about getting, and we can help you gauge if your rig can handle it.
Which quad core do you have? My q9550 easily hits 3.7Ghz. As far as video card upgrades, I have never bought into the whole idea of getting a card to match the CPU. I think it is always best to get as much card as you are willing spend. Sure a bottleneck is possible (don't think you will have much of one anyway), but I rather have a bottleneck than a card that is not good enough when a motherboard and CPU upgrade comes around.
Just noticed what your native resolution is, definitely get as much card as you are willing to spend. CPU is less of a factor (IMO) at that high of a resolution.
Its the Intel Core2. In terms of which video cards I was looking at, I am just starting to look. The gtx 660 is a great card from what i've read, as you can tell, I'm new, and did know if or where there would be a compatbility issue with the newest cards and my old machine.
8800 ultra SLI is about equivalent to an HD6870/GTX560. While they aren't a huge upgrade for you, with your CPU, I'd be looking at the HD7870 or GTX660. They are about the same price, but AMD is no longer running a free game promotion with the 7870. Therefore, if you're interested in Assassin's Creed 3, get the 660. Here's a good choice: http://www.newegg.com/Product/Produc...82E16814125443
I think the 660Ti is a bit more than you need with that CPU - you'll be bottlenecked in quite a few situations. If you're settled on spending that much (~$70 more than a 660), here's a review to help you pick the best one: http://www.tomshardware.com/reviews/geforce-gtx-660-ti-memory-bandwidth-anti-aliasing,3283.html
I always thought that any board with 2 16x PCIe slots would support crossfire, it was only SLI that needed a license and special code.
Thanks for your help. There is a overwhelming amount of info to sort through. You guys at AnandTech really know this stuff. I guess if I wanted a faster CPU I would need a new mother board? Sounds like its time for me to start thinking New computer...Never built one. How do you make sure everything is compatible?
Start a thread in General Hardware, using this thread as a template:
http://forums.anandtech.com/showthread.php?t=80121
They will get you all fixed up.
I think I can safely say yes. You Generally pay for the name, nothing more. You will lose having 1 warranty to cover anything. Instead, you will have a warranty for each item, but many last longer than one year.
Also, keep software in mind. Some of the software, like Windows, will need to be bought for the new system, as it is only licensed for the system you have now. If I have time later, I can put something together for you.
