I recently built my first computer, here are the specs
-Intel Desktop Board DX45WN
-Pentium 4 3.0 Ghz
-1.5 GB PC133 DRAM
-Nvidia GeForce 6800
-Audigy 2
-DVD Player
-DVD Burner
-200 GB HDD (im returning it tho, LOUD)
-Floppy
Here's my problem(s):
-I plug it in
-I flip the rocker switch on the power supply to the on position (I don't push the power button, it has no effect 😕 )
-The fans start spinning (including CPU fan)
-A tiny LED on the mobo lights up
-The hard drive starts spinning
Meanwhile, I get no video, and no beep codes. The floppy light is lit, and when I put a floppy in it, it dosen't make any noise. And Neither of the cd drives do anything.
Now, the first problem is that none of the fron panel display things are working. LEDs dont light, and the power/reset buttons dont work. One interesting thing about this problem is that both LEDs are "open" according to my multimeter. Does this mean they're dead? I believe that diodes should have low resistance in one direction and high in the other. I don't know how exactly motherboards are wired, but if they were busted, could it affect the power and reset switches as well?
Then I have no video. I have no idea what the problem could be. the video card's in properly, and it's little onboard fan is spinning. when I remove it, i get an ear-splitting beep. Eather the video connector is busted somewhere along the line, or the motherboard is simply not telling it to display anything.
And lastly, neither cd-drive works. Tray won't eject, no lights on the front panel. They're jumpered correctly, and the IDE and power plugs are both plugged in correctly. Again, I can only assume that the motherboard's not telling it to do anything.
I did my homework and everything (or I thought...) and I'm 99% sure everything is plugged in right. The only thing that I can think of that could be the problem is the BIOS is corrupted. That would suck serious @$$ because i'd need a new mobo AND new ram.
I am too scared to check if the processor is heating up.
:brokenheart:
help!
EDIT: I don't have any extra parts to swap out...
-Pentium 4 3.0 Ghz
-1.5 GB PC133 DRAM
-Audigy 2
-DVD Player
-DVD Burner
-Floppy
-I plug it in
:brokenheart:
help!
