1. What YOUR PC will be used for. That means what types of tasks you'll be performing. Primarily poker (multi-tabling, HEM and PT3 databases (postgres) and other poker applications), web browsing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread. i play poker full time. i don't want to spend money unnecessarily, but willing to spend for the right parts. $1000-$1500 for tower seems reasonable.
3. What country YOU will be buying YOUR parts from. USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
no
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. no
6. IF YOU have searched and/or read similar threads. yes, read a lot and i'm overwhelmed.
7. IF YOU plan on overclocking or run the system at default speeds. i intend to run at default unless convinced otherwise.
8. What resolution YOU plan on gaming with. one 2560x1600 30" plus one or two 20" in portrait.
9. WHEN do you plan to build it? within the next 4-6 weeks.
intel i5 760
evga p55 sli
g.skill ripjaws 4gb (2x2gb) ddr3 1600
windows 7 home premium
EVGA 01G-P3-1452-TR GeForce GTS 450 (Fermi) Superclocked 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video
**i could really use some help with video card(s). i am not gaming with this computer at all. if i eventually run three monitors, is it best to use two video cards? is the gts 450 overkill? i need dual dvi for the 30". will the evga motherboard work for my video card(s) needs?
80gb ssd
what's the difference between these drives?:
Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Produc...82E16820167023
Intel X25-M SSDSA2MH080G2K5 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Produc...82E16820167031
haf 922 or antec 300? is the 922 worth $100 when i can get the antec for $55?
what psu and how many watts?
finally, i don't intend to overclock. any additional cooling needed?
please let me know if i have any compatibility issues or if i'm missing anything. thanks for any help and recommendations! i greatly appreciate it!
no
intel i5 760
evga p55 sli
80gb ssd
