Heya... im having some seriouse trouble here... i built this computer (not the one im on now the one thats busted right now) toawrd the middle of summer... I recently put some ACII on it and i put a lil much on and it seemed like it was alright for a few weeks untill the computer started freezing a lot... Some how it cleared the CMOS and started running at 750hmz (i figured this wasnt a prob and I would just adjest the multiplyer) so i put it back at 133 fsb and all was well untill it wouldnt display at the win XP loading screen... it does this every time... sometimes it even locks up in the memory check but SOON as i switch it back to 750mhz it works fine... its not a heat issue (even tho i have to hold on the fan for now to fix it cos when i took the HSF off i bork the middle clip by accident) because i checked the Bios and it says its running at aorund 100degrees F witch is fine... but it just freezes up all of the time before even booting up all the way for no reason... i have no idea whats wrong with it... any one have any ideas?
Specs::
1ghz Athlon
256mb Sdram
ECS K7S5A mobo
Geforce 3 ti200 (Gainward) (i have also been having toruble with this... randome crashes saying the drivers are messed up no madder witch drivers i use for it...)
Win XP HE
if any one can help id appreciate it! Thanx in advance...
PS. sry for any spelling errors i was in a hurry when i typed this...
Specs::
1ghz Athlon
256mb Sdram
ECS K7S5A mobo
Win XP HE
