Originally posted by: wizboy11
With all those large LCD's like the new 30in. dell.
Are 19inch LCD's dead? I just bough a VP930b and was buying that monitor a mistake?
Originally posted by: cevilgenius
Of course not. It's just that people feel like showing their ePeens. I say the 19" is the best monitor size right now.
Norm
Norm
1600x1200 is far superior for getting work done. We're stuck on 1280x1024 monitors at work and while that's fine for emailing grandma and downloading porn from Bittorrnets, it's not roomy enough for actual work. I'd hate to have to produce anything on a single 1280x1024 display.
Originally posted by: ElFenix
i find that 19" LCDs are a waste of money compared to a 17" LCD, which offers the same resolution without the see-it-from-okinawa DPI
actually a 20" widescreen is almost equal to a 17" LCD in both physical height and resolution. its much shorter than a 19" LCDOriginally posted by: sxr7171
Well since we are moving to widescreen displays we need to change the way we think about screen sizes. A 20" widescreen display is roungly equivalent to a 19" 4:3 display in height (actually it is a bit smaller). In fact you could just consider it a 19" with extra space on the sides. A 24" widescreen is pretty much the same height as a 21" 4:3 with extra space on the sides.
So if you currently have a 19" 4:3 then a 20" 16:10 to many isn't an upgrade in size. So a 19" 4:3 could be considered the same as a 20" 16:10 for those who don't want the wide aspect ratio. If anything you could even think of a 20" WS as a 17" with extra space on the sides. So a 4:3 19" is actually a bigger display for those who need that space on the sides.
So, yes the numbers keep getting bigger but the vertical height is staying almost constant while we get used to the 16:10 aspect ratio.
The big problem that many feel about 19" LCDs is that the resolution tends to be stuck at the typical 17" resolution of 1280x1024. Some people actually like this for bigger text and icons though.
Problem is that 1280x1024 on a 17" is too small. Every 17" CRT I ever had I always ran at 1024x768. That screen resolution is the sweet spot for a 17". All my 19" CRTs I ran at 1280x960. Anything higher and it was just too small.
Once you've used a 19" CRT for several years you ain't going back to a 17" screen no matter what the technology.
