A few weeks ago I bought a 1996 Subaru Outback Wagon 2.5L with 199k miles for dirt cheap. 20,000 miles ago, the previous owner had the head gasket, cam seals, belts and water pump replaced and provided me the service documentation. There are no visible oil/coolant leaks. I have not noticed the car smoking at all.
My problem is the car uses 1 quart of oil about every 600 miles. I found out the hard way, just over 1800 miles from my last oil change the engine started making a bad tapping noise. The tailpipe is completely black. The engine has never overheated on me and the oil light did not turn on. 3 quarts of oil later the noise completely disappeared and all seems well. This is my first Subaru, so I don't know if this is normal or not for a car of this age and mileage. (I'm used to older Honda's and never had this issue.) Is this something I need to worry about? Other than frequently adding oil, the car seems to run just great.
Second issue; my Automatic Transmission light blinks upon starting, and I'm getting bad Solenoid codes. Bad codes continued after transmission fluid and additive were added. The car shifts fine 99% of the time. Honestly I probably wouldn't have noticed anything had I not run the codes, thus becoming aware of a transmission issue. How much should I expect to pay to have Solenoids replaced, and what are Solenoids anyway?
I don't mind putting some cash into this car since I bought it for so cheap.
Any help would be appreciated!
