EarthwormJim
- Oct 15, 2003
- 3,239
- 0
- 76
Grats on the car, I almost bought a 540i too.
Definitely check to see if you have a nakasil engine. If you do you might be able to get a new one from the dealer.
As far as suspension, look into getting Bilstein Sports struts and either H&R or Eibach springs. Sachs is also good as mentioned above.
Also if you EVER need OEM parts, only order from http://www.autohausaz.com/. They are the cheapest I have ever seen for BMW OEM (or OE) parts.
