1900XT votage regulator temps
Fistandantilis
I noticed that the voltage regulator on my 1900XT gets hot, it ussually gets as hot as the core on my card I have seen it is high as 80c. The card is not giving any sort of errors, no artifacts or VPU recoveries.
Do you guys think that this is a bit high? is it a bad idea to take the sink off the regulators and add as5?
thanks
If you can...change the stock cooler and put a fan that blows right across the regulators.
Does the stock cooler blow air out of the case?? If it does then forget the aftermarket cooler and just add a small fan that will blow on the regulators.
Before I added the fan, my regulators would also go to about 75 degrees. I then went to watercooling and added the fan and the regulators don't go above about 60 degrees anymore and that's when it's overclocked as per sig.
I connected the fan as a system fan on the motherboard. That way, the fan speeds up as the system temps go up, which happens when I play games.
Those voltage regulators run hot (the little devils under the red heatsink), so 80C is nothing to worry about.
I'll possibly take the bullet here - but I want to point out - it appears that the red heatsink on the 1900's VRM is designed to have proper clearance only when the gray putty material is there - if you take that off and apply AS5, you might have to file the "feet" of the heatsink down in order to ensure contact.
I'm running my X1900 on water so I had to get some VRM cooling in order to OC - I mounted a 60x10mm quiet Delta fan onto the card over the VRM, added some MicroCool mini-sinks to the coil blocks. VRM temps max out in the low 60s now, with a 700/800 1.45 VGPU overclock applied - much better.
Originally posted by: gersson
I'm begining to think I'm a thread killer. EVERY SINGLE THREAD THAT DIES -- I'M THE LAST POSTER X(
LOL thats funny, that happens to me all the time.
well if 80 is OK then I will not get to worked up about it
Thanks fellas.
