19" Nec lcd $30 AR HOT HOT HOT HOT
d94
595
INSANE CRAZY DEAL
@ your local office depot
http://ec1.images-amazon.com/images/P/B0002W2SRO.01.PT01._SCLZZZZZZZ_.jpg
http://images.amazon.com/images/P/B0002W2SRO.01.PT02._SCLZZZZZZZ_.jpg
http://www.officedepot.com/textSearch.do?uniqueSearchFlag=true&Ntt=964344+
on clearence for $200 and has a 100 and 70 dollar REBATE
IMMA GET TWO IF I CAN!!!!!!!
rebates: https://www.web-rebates.com/officedepot/index.asp
Just type 964344 in the Product SKU line on the left, and it should bring up two rebates
Panel type: TFT Active Matrix
Display size: 19"
Diagonal viewable screen size: 19"
Dot pitch: .294mm
Contrast ratio: 450:1
Glass surface: Anti-glare
Horizontal viewing angle: 130 degrees
Vertical viewing angle: 130 degrees
Response time: 16ms
Brightness: 250 cd/m2
Input signals: Analog and DVI-D
Input connector/cable: 15-pin dSub and DVI-D
Maximum non-interlaced resolution: 1280 x 1024 @ 60 Hz
Horizontal frequency: 31.5-80 KHz
Vertical frequency: 56-75 Hz
Power consumption: 56W
Environmental conditions: Operating Temperature: 41-95oF; Operating Humidity: 30-80%; Operating Altitude: 7999 ft
Voltage rating: AC 100-240V, 50/60 Hz
Audio: Stereo speakers built into "soundbar"
Color: Silver
Width: 16.6"
Height: 16.7"
Depth: 7.7"
Weight: 13.2 pounds
Warranty, parts: 1 year
Warranty, labor: 1 year
http://www.amazon.com/gp/product/B0002W...g=UTF8&n=172282&s=electronics&v=glance
cutty
311
Not available in Long Island either. :(
Every time I saw anything is low availability, then it was never available in here!!!
foolish501
3,387
called my local store, they show no stock at any store in my state or neighbouring states
venk
Banned
Dec 10, 2000
7,449
Having trouble pulling it up, looks like it might have been caught. I will drop by the BM store tommrow, anyone know when they open?
CKDragon
3,875
Just a friendly tip...
NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER NEVER
CALL A STORE ABOUT A HOT DEAL!
While it's unlikely that places have these in stock, calling about a deal will quite possibly alert them to the hotness of the deal and either fix the mistake (if it was a case where there is a mistake) or give them an opportunity claim the hot item for themselves. You must have been sleeping during Hot Deals forum 101. :p
You're lucky you're here. On FW they have special task forces reserved for those who call the stores. :p:)
CK
CKDragon
3,875
Trey22
5,540
Someone buy an extra one for me, I'll pay for shipping plus a little $ for gas :) .
jlee
48,518
223
It comes up as $199.99 - after I select my location & a store, it no longer appears. :(
foolish501
3,387
CK
that's just crazy, so you can never call a store and ask if they have an item in stock ? i call my local store all the time to check for see if they have items in stock, saves me a trip if they don't have them in stock.
THRILLHOv
397
nah, foolish, he's right.
its not for all deals, just the special ones, the unadvertised ones, or the ones where you kinda have to work the system
imagine if you call the store and say "do you have any of these in stock?"
the guy types in the # to his computer, and he sees the LOW price and rebates... but there's only one left...
"nope, sorry we're out" says the salesman.
and he goes home with a new monitor.
uglywolf
140
This is your typical OD clearance. Very hard to find once they get down to this level. You'll have to go to the store and hope you get lucky or pick up a demo item.
This is why it shows as discontinued online. You can have a very rough idea of inventory at your local store if you use the in-store pickup feature. If it doesn't show in stock at a store, go back to the cart, select delivery, then select in store pick up again. This allows you to pick another store. Eventually, if you're lucky, you'll hit one that SUPPOSEDLY has it in stock. However, this doesn't mean it's actually there, this is where you cross your fingers and go there and see if it's actually in stock. Yes, I've struck out many times doing it this way but it's better than driving around to different stores blindly. And yes, I've gotten lucky and got a few clearance items this way too so YMMV.
Btw, last week I found two stores that had this for in-store pickup but it turned out they didn't have it in stock so I gave up. I'm in Southern California.
