180mm fan holes measurements?
lsv
1,610
Hey all,
I'm looking to find measurements for a 180mm fan, I am cutting some metal to build a port blocker for a Fractal Arc Midi for a friend and can't find exact measurements anywhere. He did tell me 165mm edge of hole to edge of hole but I don't want to muck it up.
A PDF that could print 1:1 would just be perfect :(
Is my best bet to find a 180mm fan locally and pencil in the measurements?
Thanks,
Lsv
lehtv
11,897
74
You could ask someone with an 180mm fan to do the measurements for you. Sorry, I don't have one... :p
