1800MP not reporting right speed!!
You have the fsb set to 100. Change it to the 133/266mhz setting and it will be at the 1533mhz clockspeed its supposed to be at. 🙂
Jason
If its truly the AU31 model, then is is the nForce2 chipset. You can run any thoroughbred cpu and most barton cpu's which will be much cooler and perform better.
Jason
Jason
i did check the jumper as it was on 133/166 and not on the 100mhz pins
i used the same board with my xp3000
hmm may have to mess around more in depth
