17" lcd monitor with highest refresh rate???
Jincuteguy
380
what is the 17" lcd monitor that has the highest refresh rate at 1024-768 resolution??? (Plz dont talk about the response time, im asking about the refresh rate because i want to play games with V-sync on )
Excelsior
19,047
18
Umm..first off..the native Res of 17" lcds is 1280x1024. Second, I believe the max of any LCD is 75hz. Even then.why does it matter..vsync at 60 would perfect.
Mem
21,476
13
Refresh rate for LCDs is not important since they don`t work like normal CRTs,the response time is the important part.
Getting back to your question most LCDs have 60Hz,70Hz,75Hz with 60Hz being the most common but as I said it makes no difference if you run it at 75Hz or 60Hz with a LCD.
