17" LCD Monitor $269 AR AC Staples
Banana
3,132
23
This is a "Special Savings" offer available beginning August 10:
NESO PIXO AT700S #514243
Neso 17" LCD flat panel monitor
$379.98 - $80 mfr. mail-in rebate = $299.98
Throw in a coupon for even more savings.
[edit]Use the $30 off $150 coupon to lower the price to $269+tax[/edit]
Only caveat is--what crappy brand is Neso?! :D
"This product not available in all stores but can be ordered for delivery by calling 1-800-333-3330 or online at www.staples.com"
Staples Neso 17" LCD
ByteMeAgain
(Not sure if it is the exact same model)
http://www.nesousa.com/products/ld/pixo700.asp
PIXO 700
LCD Display: 17" active matrix TFT LCD panel
Pixel Pitch: 0.264 mm(H) x 0.264 mm(V)
Display Area: 13.03in(H) x 10.64in(W)
Brightness: 250 cd/m(typical)
Contrast Ratio: 400:1 (typical)
Input Signal: RGB Analog
Input Connector: D-Sub mini 15-pin
Display color: 16.7M
Viewable Angle: L/R +80 degree ~ -80 degree, U/D +80degree ~ -80degree
Recommended Resolution: 1280 x 1024
Plug & Play Support: VESA DDC 1/2B
Front Controls: Auto Adjust, Mesu, up, down, Select+, Select-, ESC, Volume
Power Saving: VESA DPMS Standard
OSD: Brightness, Contract, Auto Adjust, Phase, Clock, H.Position
V. Position, Sharpness Color Temperature, Language, OSD H/V
Position, Video select, Recall
Power Consumption: 35W (Typ)
Speaker Out: 1 watt + 1 watt
Audio Input: Stereo mini-jack
Compatibility: PC99, Windows® 95/98/ME/2000/XP, Macintosh®
Dimensions(inches): 17.05(W) x 17.64(H) x 7.87(D)
Safty & EMI: UL, CSE, TUU/GS, CE, VCCI, FCC(DOC)
Net Weight: 14.33 lbs lbs
http://www.nesousa.com/news/default.asp?article=006
dmak
anyone have the rebate link. Went to staples and it doesn't state any 80 dollar rebate to make it 299.00.
CheetahMk2
517
Not necessarily. I posted a post about a "Wholesale hot" TFT at Costco, 25ms for 330 no rebates. Fry's have a Hyundai ImageQuest L70S for $300 AR. I remember a Sony 18" over at Dell that could be had for $330 after some coupon madness. There are deals out there, you just have to look really hard.
Tiembo
528
Originally posted by: woodscomp
I second the Hyundai panel deal at Fry's.
Picked one up, looks pretty good. 1280x1024 native. I looked around, and I *think* this LCD has a 16ms refresh time. Built in speakers, too. No DVI though :(
Banana
3,132
23
Update: Use the $30 off $150 purchase to lower the price a little more.
gouda96
835
Wait a second...the lcd from this thread, or the hyundai from fry's?
Tiembo
528
The Hyundai from Fry's.
GoatHerderEd
498
I just got one of the staples ones. It looks nice! one hot blue pixle though. I scored on the coupons, they took both. $327 out the door! $80 mir will be sent in, making this a sweet deal. Bump for a great deal!
Hook
159
Mine should arrive Friday. I'll let you know what I think once it gets here (I'll play a bit of America's Army...). Hopefully it doesn't suck because the closest Staples to do a return is 2 hours away...
weepul
5,134
www.hd-trailers.net
which 2 coupons are u referring to? i only see $40 off $200 and $30 off $150 but they're not combinable.
//krunk (^_^x)
Hook
159
Mine arrived today. Only been using it for 15 minutes or so but so far it looks really nice. Maybe I'm easy to please, but I don't really notice any ghosting or trails. I played a round of America's Army and it looked great.
So, I'm happy that it looks like I won't need to drive the two hours each way to return it to Staples.
PS. I also used the free luggage coupon. The "luggage" isn't really anything more than a black gym bag... But it was free...
PPS. The one downside to getting an LCD is that I can tell I'll want to replace the second CRT monitor on my dual display set up...
Tiembo
528
Same here, dude. Although I'd like to get one that has DVI. I'm hoping that a really killer deal will strike on Black Friday.
What a week for good LCD deals! :)
NICKel
1,774
Sorry, this offer has expired.
(sigh)
