I have an older model lian li card reader (CR-31A I believe) which doesn't support SDHC. I found a hotfix that MS released which added the SDHC support for xp32, but I can't find anything for xp64.
It seems to be a pretty straight forward hotfix, and plenty of people are successfully using SDHC cards on readers that "don't support" the format (xp32). I'm assuming the hotfix was originally released to enable support for SDHC period, but also ended up allowing the non-SDHC readers to work as well. XP64 supposedly doesn't need the hotfix because it already does support sdhc, but no hotfix means no using old card readers. Am I right in this? Does anyone have any more info or know of some type of work around that might do the trick?
