1600x1200 max res for DVI output?
DVad3r
5,340
Q. Is there a maximum resolution for the DVI output?
A. Yes, it is 1600x1200.
Is this true??? How come I'm running at 1680x1050 on my FPW then using DVI on my 7800 GTX? Should I use regular vid connector instead of DVI then?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Single link DVI can go up to the native res of the 2405, 1920x1200 without issues.
Mar 19, 2003
18,289
1) See Jello's comment
2) 1680x1050 is actually less overall pixels (therefore less video bandwidth) than 1600x1200
3) Never use VGA on an LCD at high resolution if you can avoid it ;)
JBT
12,094
I agree with all comments.
DVad3r
5,340
Ya I've been running my setup all this time with no problem, I don't know why that would be on the BFG site FAQ, maybe Ill send them an e-mail.
stelleg151
822
I think techincally only dual link DVI can go above 1600x1200 at 60hz. Not sure though, someone correct me if im wrong.
