wwswimming
Banned
would this transfer heat better than a heat pipe filled with water ?
I aim to please.Originally posted by: TrevorRC
Originally posted by: Howard
No.
I love your answers.
Originally posted by: GalvanizedYankee
151 is supposed to heat up your pipes OP. 😉
H2O is probably the best liquid for heat transfer on this planet, for our use=CPU & VGA cooling.
Google latent heat and read. Consider that the H2O could be under a vacuum, reducing it's boiling temperature.
...Galvanized
They are certainly used, but the properties of water make it a better heat pipe fluid.Originally posted by: fatpat268
...Galvanized
Wouldn't a form of alcohol, whether it's isopropyl, methanol, or ethanol, be efficient for heatpipes?
According to Arctic Cooling, they use water in their heat pipes.Originally posted by: Parkre
The fluid you use is ultimately determined by the temperatures you plan on working at.
They use ammonia in the permafrost heatpipes on the alaskan pipeline. The heat is pulled from ground (when it starts to warm up) and released into the atmosphere to keep the ground frozen.
Using water at CPU temps in a heatpipe (with it vacuumed of course), all liquid would turn into gas (which would not a be a heatpipe anymore). Then to compensate, the pressure has to very very large in order to turn the gas back into liquid. This is the major reason why you don't use water
Originally posted by: lenjack
Look at the upside...if it doesn't work, you can drink it.
Might be of interest http://www.benchtest.com/heat_pipe1.html
This may not be up to the standards of up & coming wanna be engineers but it's
good enough for me 😉
EDIT: Be sure and read all three pages.
...Galvanized
Originally posted by: Lucent
R-134A is a piss-poor fluid for heat pipes. It has to be under tremendous pressure to liquify in the pipe=not good. With a pipe of that diameter, the performance shown on the page is pathetic. 😉
When we were doing our project, Our R-134a was under 200 psi at room temperature and only got up to 235 when heated up. We used a TEC (peltier) as a heat source. We were trying to keep a soda on the other side of the TEC cool.
And Galvanized, we used that benchtest.com as one of our references. It's where we got the idea for the R-134a adapter.
My gf, who just graduated with her mechanical engineer degree was in the same class. I built my silver water block (silver round coin in a copper block, it turned out awsome) and her group built the test setup for it. They ran the same test with the swiftect apogee, and mine performed better..yay. However, since we were testing it right up til the end of the semester, and I started a new internship right away, I haven't had the chance to put it in my pc.
