Guys,
My plan falls apart when my old BMW E46 (3 series) put up an error code P0734. It can be something as simple as a sensor or something as expensive as mechanical issue with the transmission/torque converter.
The car is 14 years old with 176,000 miles on it. Ive changed over the years.
+ Fuel pump
+ Fuel filter
+ Gaskets (VCG and oil housing gaskets)
+ Radiator, hose
+ Water pump
+ Belt tensioner
+ Control arm bushing
+ Shock absorbers and coil strings (rear).
+ Spark plugs, coils, vacuum hoses etc.
The car is worth practically nothing (around $2K) but I still really like it. My better judgment said that if the repair comes out more than $2K, just junk the car and move on.
The issue is, I was hoping to drag it out for another 3 years, waiting for a Tesla Model 3. If I get a new car now, it would be the wifes choice: a Lexus or some sort. Two reliable low millage cars + a 97 jeep wrangler for fun = no chance for Tesla to sneak in the garage for the next 10 years or so.
I can fix up the jeep and hope that it last me longer. However if it ever leaves me on the side of the road, Ill never hear the end of that story from my better half.
What would you do?
+ Fuel pump
+ Fuel filter
+ Radiator, hose
+ Water pump
+ Belt tensioner
What would you do?
