1366 CPU Cooler
MERX2006
PC CASE; ZALMAN GS 1000 ( NO COOLER CUT_OFF )
GPU ; GTX 460
MOBO ; Gigabyte X58A-UD3R
CPU ; i7-950
NON-GAMER / NON-OVERCLOCKER
highest load is DVDFab Blu-ray Copy.
I guess that is enough info to imagine my Case ( spec. ) Environment. I wish the Corsair 550D was available when I built this PC. It should be said," I wish I had the knowledge then as I do now."
I am looking for CPU COOLER with a no problem install and will do the job. I have scanned through tons of reviews with not enough personal satisfaction to make a choice.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now I am back to considering Corsair H80 or H100.
Help? Where is the SANDIA Labs licensed CPU Cooler? And, will I need it?
You're contemplating an over-hyped and ultra-marketed H100 for what? $120? If anything, part with $30 for a CM 212 EVO.
