13000mah and 20000mah
tsupersonic
867
21
Depends what phone... If we're talking about an iPhone 6/6s, then you could get more charge out of 13k/20k battery packs than something like a G4/Note 5/6P, etc.
paperwastage
1,848
Take that number, multiple it by 0.7 to factor in power losses from voltage conversion
So 9100 and 14000mah
Divides those numbers by the capacity of your phone. Eg, nexus 6p is 3450mah
Note that some external battery manufacturers may overstate their mah rating
Yuriman
5,530
141
How big is the battery you have in your Note 2?
If it's 3,100mah, and you're charging it from a 13,000mah battery pack, basic math tells me that you can get no more than around 4 charges, assuming no conversion losses and all of the batteries have their full rated capacity.
paperwastage
1,848
Charging up my note 2.
note 2 has 3100mAh battery
so about 2.9x and 4.5x respectively. batteries degrade, so expect those multipliers to go down in time
think about replacing your note2's battery, or get a zerolemon 9300mAh extended internal battery
core2slow
774
20
I have a 4100mah battery so probably 2.5x and 3.5x, respectively, with voltage loss.
