I found a discarded battery backup power supply once & converted it.
They have 12v to 120v converters in them and usually get thrown away when the batteries go bad.
Most of them have 12v batteries inside & any car 12v battery can suppy their power.
Maybe even a motorcycle 12v if you have a good inverter ? or don't run it long ?
Each cell in a battery makes 2 volts. 2x6-12v
Some ciggerette lighters get dirty & burnt and may not make a good connection sometimes.
A poor connection could interfere with sufficiant power supply ?
There are other plugs that you can use.
Any plug that can't be put in two or more ways will do ?
Such as a 120v two prong lamp cord if one prong is big & one small
will surfice as a DC volt plug. Use the big one as ground,
then any lamp cord of reasonable size is a good cord for transfering power.
16 gauge prefered, 18 ok, etc. Standard house wireing is 12 gauge (12/2 w/ground)
You can wire a house electrical outlet up to your 12 volt battery to transfer the power.
An old 3 prong extension chord will work. Cut the FEMALE end off at 3 foot length & hook it to your battery.
then hook the other end to your converter. (Cut to shortest length allowable under all conditions.)
If you are converting 12v DC to 120v AC so you can run a transformer to get 12v DC into your laptop,
you'ld be better off running the 12v into your laptop.
Every conversion of voltage results in a power loss of some kind.
DC wires loose power as length increases fairly rapidly ?
Get a penton wheel, hook it up to a 60 amp truck alternator, get a manual adjustable Chrystler voltage regulator,
& hook it up to the garden hose ? hahahahahaha
I made a battery bank charger that way using a Briggs & Stratton 5 horse gas motor and it worked fine.
SERIES v PARALELL
If you take two 12v batteries and connect the positive from one to the negitive of the other
that leaves one pos & one neg not being used. The voltage between those is 24v. (Series)
Hooking up one 12v & one 6v that way gives you 18v.
Using the same technique and knowing that each cell is 2 volts, you can drill the batter top and put a bolt into
the led connectors between the cells and end up with any even voltage lower than the max you have available.
2,4,6,8,10,etc
If your two 12 volts were hooked positive to positive & neg to neg you have a 12v battery with twice the amps &
it runs things twice as long. = (paralell)
Well there are some different ideas for you to kick around.
I hope it helps somehow.
Bitdog
