I have upgraded my system with a new PSU. A HIPER ATX 525W HPU-3S525 Triple Fan, Silent, PFC
Review: http://www.bit-tech.net/review/356
Im having instability when playing games etc. The computer simply turns itself off (and doesnt reboot)
The rails are all withing spec in bios (12v at 12.02) but in windows it shows 11.43 at idle. Doesnt seem to change much during load. This seems awfully low. I read reviews of the hiper, and it was supposed to have a solid 12V rail. Its rated at 29A max at 12V, 20A normal on the sticker.
I use 3 harddrives, 2 DVD drives, a couple of fans and a Gainward 6800LE GFX card.
It seems to drop from 11.9 in windows and to 11.8 etc. and stopping on 11.43 it seems.
(ASUS probe measures the voltages)
Any suggestions?
Thanks for your time.
sincerely
Trond V Bjerke
SYSTEM:
Power supply Hiper 525
Motherboard Asus A8N-E Deluxe
Revision 2
BIOS 1009
CPU Athlon64 3000+ socket 939
Core
Memory (2) 512MB twinmos twister 3200 C2 modules
Voltage Manually set to 2.6 volts
Timings AUTO, not sure
Primary video card 6800LE at 16v6 (6800gt)
PCI slot #1 (top) empty
PCI slot #2 empty
PCI slot #3 empty
PCI slot #4 empty
PCI slot #5 empty
PCI slot #6 (board only has five PCI slots)
Boot drive 160GB samsung 161N spinpoint 7200 8mb cache
Interface Serial ATA
Controller hosting this drive
Jumper setting not applicable (SATA)
Additional hard drive 160GB western digital 7200 8mb cache
Interface Parallel ATA
Controller hosting this drive nForce3 standard ATA controller, primary channel
Jumper setting Master
Additional hard drive 200GB Sata Western Digital
Interface
Jumper setting
Optical drive #1 Liteon 851s DVD burner
Controller hosting this drive nForce3 standard ATA controller, secondary channel
Optical drive #1 Pioneer DVD reader
Any suggestions?
sincerely
Trond V Bjerke
SYSTEM:
Revision 2
BIOS 1009
Core
PCI slot #2 empty
PCI slot #3 empty
PCI slot #4 empty
PCI slot #5 empty
Interface
Jumper setting
