RobertMcDonald
Simple question: on a power supply, what is the minimum voltage the +12V should be at to avoid damaging components?
Thanks!
Thanks!
Originally posted by: jonnyGURU
You don't "damage components" with low 12V. It's high 12V that does the damage.
Low voltage doesn't break things? I was told in physics way back in high school that lower voltage made the amperage go up which resulted in higher circuit friction and thus heat, burning out components.
For example: High end video card, same power supply, 12V at 12.2V works fine. 12V at 12.6V works, but runs hotter. 12V drops to 11.5V, PC locks up. 😉
Now do a reality check with a multimeter.Originally posted by: RobertMcDonald
Like this?
My power supply has been running at 11.52V (according to ASUS Probe and my BIOS) and I'm wondering if it has something to do with my system sucking for the past... ten months. 🙂
