Im currently running an old celery 333A at 416, the case, PSU, CPU, and motherbaord all came from the same place i guess about 2 or more years ago. When i bought it, the description said it was a 250Watt Power Supply, but recently i ordered an Epox 8KTA3(Spelling?) Motherboard and Tbird 750 combo and that sparked me to look at my PSU and lo and behold on the side it says: TOTAL O/P 125W. Im assuming that means Total Output Power, which as you can see is NOT 250 like i was led to believe. I had planned on hopefully winging it with 250 until i found a good deal on a AMD approved ah heck but now it appears things will change. My question is this: Does TOTAL O/P mean something completely different and my PSU is actually 250 or was i ripped off those years ago? And if so, there is prolly no chance of me running my system on a 125 wat PSU correct? The manufacturer is, as far as i can tell, Century Electrical(The electrical is (mis)spelled on the side of it as Eiectrical, the model number is SPX-250C\2.01. Any advice\good places to buy PSU's would be appreciated.
