120mm Yate Loon Fans $3.00 each @ SVC.com
wazzledoozle
1,814
Very nice. I paid around $5 a fan for these a few months back, silent and push a fair amount of air.
Navid
5,053
That is the L version (less air than M). Is the M version the same price?
coolzero16
432
bought a few of these on some buy 2 get 1 free deal a while back came out to like 4 of em for aorund 15-16 bucks this seems like a great deal too
good fans also i put them in my antec p180
SonicIce
4,771
Sure Yate Loons might be great fans after you install them, but wouldn't they get loud over time due to the sleeve bearing?
JSLIM
703
that's why you stock up. :p
mindless1
8,729
1,745
Yate Loon fans are low quality junk relative to most major brands.
Because of their low torque (low cost magnetics and motor) they are suited to quieter, lower RPM use. That can be a very desirable thing to some people, especially those who lack the ability to implement a fan throttling method that doesn't result in pulsating noise. The same can be done with other much better fans though, like using a ~ 68 Ohm resistor with a Panaflo you get the low noise, far longer runtime, and lower vibration related noise.
They are poorly balanced, used an inferior bearing to almost any fan manufacturer's name brand (opposed to PC parts relabelers' brands or generics), and will have a shorter lifespan with short maintenance interval to relube or replace them.
This is common knowledge to anyone whose had to pull Yate Loons out of power supplies or cases, though on a vertically oriented case mounting they do tend to last longer than in a PSU.
The ideal fan isn't 25mm thick though, the pressure potential of such a low ratio diameter to thickness starts to take it's toll so to get best airflow rate you have to have large openings in the case- which let more noise out, and they're poor for filtered intakes as well if the filter is more effective than ornamentation.
cmv
3,490
Great. Where's the deal? Is it pretty hard to find a good deal on Panaflos? I'm building HTPC and I'd like to go with them as I've read similar reports to what you've written above before but...
mindless1
8,729
1,745
Originally posted by: cmvGreat. Where's the deal? Is it pretty hard to find a good deal on Panaflos? I'm building HTPC and I'd like to go with them as I've read similar reports to what you've written above before but...
SVC has had deals, you might check there. On the other hand, a computer is a few hundred dollars, why is a "deal" necessary on the parts that are typically shortest lived? IMO, whatever it takes to have a fan that lasts the life of the system is a warranted expense and whatever deal can be found is just icing on the cake.
SonicIce
4,771
Originally posted by: 88NovaTwincam
I think you have it backwords! Sleeve bearings are not as noisy over time compared to ball bearings..
are you sure? I thought ball-bearings had less friction.
mindless1
8,729
1,745
IF you were comparing two fans virtually identical (in RPM, blade design, mounting or free-air, motor, magnet, balancing, etc, etc, etc) then the sleeve bearing fan is subjectively quieter when new, partially because the ball bearings make a higher pitched noise that doesn't blend in with surroundings as well and that the human ear is fairly sensitive to, directionally.
This is also considering a certain minimal RPM and above, as the lowest RPMs used by many for very quiet systems will make the difference between sleeve or ball bearing indiscriminable. The higher the RPM, the more noticable the bearing noise.
Once a sleeve bearing fan starts to wear, it inevitably wears the bearing in a somewhat elliptical shape and slaps around, progressively wearing out the bearings at an accelerated pace. Since sleeve bearings tend to have lower lifespan (except the most high end bearings in precision made and balanced fans), they will eventually be louder than their ball bearing counterpart- if you're lucky. If you're unlucky, they will instead just fail to spin up from a cold start and some part of the system bakes instead.
All else is seldom equal as mentioned above. Ball bearings themselves are more expensive than sleeve bearings and are typically used in higher quality fans, with better blade molding, better balance, smoother motor operation. These factors can easily offset the bearing type for noise purposes, unless you have a particularly high quality sleeve bearing fan such as Papst or Panaflo, or get lucky and your low quality fan is (randomly) well balanced and you relube or replace it.
So in summary, it's not just a matter of bearing type and most people who seek these low RPM Yate Loons are wanting low noise, a noise level which requires low enough RPM that either type of bearing would be similar enough in noise level and frequency- until the fan starts failing. You have to use a fan speed reduction method with most fans, and these Yate Loons too as they are not silent at default speed, 12V operation.
They do start out closer to that ideal and due to their low torque, are pretty easily put into an even lower RPM by pulling air though a case, but it's all a matter of how quiet you need the system and how you want to reduce that RPM- just about any fan will be quiet enough given a good RPM reduciton method, except for a few thicker models with very powerful magnets, high torque types tend to start making pulsating or clicking noises.
One example of such a fan that doesn't respond so well to greatly reduced voltage, or even current limiting, is a Sunon 120 x 38mm, though otherwise it is a good quality fan, certainly a lot better than these Yate Loons if airflow and life are more important than low RPM, low noise operation.
Otherwise, you can randomly grab any medium to better quality 120x25mm fan and expect to be able to run it as quiet as a Yate Loon, with a current limiting control method, and expect longer life too.
SubRosa
8
OK, so maybe these fans blow, but the price is right. I'm in for three, plus a couple of the REALLY quiet Enermax Enlobal Bearing (17dbA and 44CFM) fans, too.
Wow, I've never had a fan with "removable blades" like these Enermaxes. I bet they run even quieter with all the blades off. I hope that doesn't decrease the CFM too much.
SubRosa
8
Oh, yeah, I really liked Mindless1's thoughtful--even erudite--explanation of the ball bearing vs. sleeve bearing noise issue. Makes me wish I were an engineer instead of a half-baked secret agent.
One reason I still went for the Yate Loons is because my personal favorite RPM reduction method is to just stick a pencil into an annoying fan when I need some peace and quiet. Cheapo fans are definitely best for this. I tried it once with one of those Delta high-RPM/CFM screamers. What I got was transiently elevated decibel output--not to mention a thick cloud of wood and graphite dust.
AkumaX
12,643
anyone have these and a fanbus?
curious because they're rated 28dba @ 12v. i'd go a little quieter and maybe use a fan controller
to push it down to say 8v-10v. anyone try this and is it still quiet?
Pens1566
13,474
10,922
Originally posted by: Traveler
What's L and M versions?
Could you enlighten me?
L = Low speed (1350 rpm)
M = medium speed (~1600rpm)
L's are much more common than the M's
SubRosa
8
O mindless1, in your earlier excellent comment, don't you mean either a HIGH diameter to thickness ratio OR a low THICKNESS to DIAMETER ratio?
Just trying to clarify the numerator/denominator issue on behalf of my shadowy employers.
