Originally posted by: GalvanizedYankee
Just for the exercise I looked for about 30 minuets, found nothing.
Crazy solution. Buy 4-60x10mm fans, sand two sides of each on a flat surface, super glue
all four together=instant 60cfm 120x10 fan at about 32dBA
😀 These fans can be found at
BGMicro.com or AllElectronics.com for < $2.50. They will start/run at 5V and are near
silent at 7.5V. At 8" I can not here one of these at 7.5V.
If you go for this, just make sure all the tails are to the outside. Solder the leads together
and join to one plug.
I've done this when pairing 92mm fans as front intakes to replace paired 80mm fans.
Using a double layer of waxed paper on a flat surface, it's quite easily done. I use the
super glue from ACE Hardware that comes in a nail polish type plastic bottle. A light coat
to each, almost let it dry, then a flood coat to one, press together, hold for 30 seconds,
let set for 15 minuets then join the others.
I just checked. This joining of four 60s will place the mounting holes further out by 1/2 the
hole diameter.
Better solution=RMA your present PSU, spend that money on a Fortron/Sparkle that is NOT
modular, then install a 120x25 fan of choice. I spent the same money on a Zippy/Emacs
HG-2 6400P from
www.buildtoorderservers.com=incredably good PSU.
...Galvanized
