Don't this so, cause the 120mm fan sits inside the case at the inside end of the fan duct. I don't see how you could do it, since the space is so small. Its hard enough fitting a large HS cause of the fan duct, sometimes you don't use a fan at all and just let that 120mm fan pull the heat off the HS.
Were you thinking of putting the radiator inside the duct, that would sorta work, but then you would need to add 2 60mm fans to help pull out the air thats flown through the radiator, cause lots of air presure is lost flowing through the radiator.
Could put a radiator on the top chimney fan, maybe make the hole bigger for a larger fan, it probably will be a little tight, just make sure it clears far enough from your PSU intake.
GiZzO's Fan Database Page
