- Jun 3, 2011
- 13,782
- 2,284
- 126
Hi guys.
I've recently been very disappointed by my case/cooler, to the point of disbelief.
I have a CM Nepton and a Cm HAF XB. Besides the ridiculous fact that the front mounts for 280 work, but don't let me put the front panel back on the case, this AIO is so loud i can't hear the game sounds anymore.
I'm running a 4670k @ 1.22V, with low temps 30-31c, but as soon as anything launches, it skyrockets (no, its not adaptive mode) and the fans become ridiculously loud. Eventually they come back down, but they are just too loud.
So, i'm going to try a 2x120mm mount on the same rad (using 140mm now), and i need some decently quiet .. no, some superbly quiet pwm fans.
I'm willing to lower the voltages if needed, the chip only does 4.3 anyway, and will do 4.1 at stock 1.05v, so whatever. But this noise has go to go.
tnx
tnx
