I have a question about some fans I'm looking to purchase. I'm no stranger to PC building and modding. But, I have a few questions (sarcastic mostly) about (3) fans.
1) Yate Loon D12SL
Model: D12SL-12 ( all orange )
Air Flow: 47 CFM
Fan Speed: 1350 RPM
Noise Level: 28 dBA
Power: 1.8 watt
Fan Size: 120x120x25 MM
Connector: Includes a 3-pin motherboard power / RPM connector and a 4-pin standard power connector
2)Delta 120mm Tri Blade LS
Specifications: 120x120x25mm, 57.21 CFM @ 1950 RPM, 31.0 dBA, 1.68 watts, .14 amps, Maximum Air Pressure 2.54 mm H²O, 12v DC, 3 pin Molex header connector.
3)Scythe SFF21D 33.5cfm
Specifications: 120x120x25mm, 33.5 CFM @ 800 RPM, 8.7 dBA, 0.10 amps. Each retail package includes a special 3-4 pin power adapter with split connectors.
Now, the Yate Loon, I'm familiar with. The Delta I'm familiar with. But, the Scythe with those specs? 😕 33CFM @ 800RPM?
1) Yate Loon D12SL
Air Flow: 47 CFM
Fan Speed: 1350 RPM
Noise Level: 28 dBA
Power: 1.8 watt
