I have 2 HD's running about 40c (tad more on intensive use). Since I have lots of room in the mounting bays I was thinking of installing 120 mm fans over each of the HD's.
These should make for a quite solution and move a fair amount of heat. Would it be best to have the fan blowing on the HD or drawing air away from it?
Anyone using a 120mm fan for this purpose?
